Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Magna TF - need help with my car stumbles when accelerating
    Aug 2010
    Default Magna TF - need help with my car stumbles when accelerating
    Magna TF 1997 V6 3.0. 140,000 km.
    Sorry for my English in advance. All was good until it started to stumble pretty bad after waiting on a light some day. Hardly managed to get home. The idle is almost fine, just a small sputter every few seconds. It runs ok too if I press on the gas when parked. But when driving it stutters and stumbles really badly as I’m pressing on the gas. Have to use the accelerator very gently to get it rolling at all. Sometimes it "wakes up" and runs very well as it always was in the past.
    So what I have done so far:
    - timing belt adjusted (the cam seals were leaking anyway and it looked like the belt has jumped a tooth when I checked it before doing the work)
    - distributor cap and rotor renewed
    - cylinder compression test - ok
    - inlet manifold gaskets, plenum chamber and throttle body gaskets renewed
    - throttle body cleaned
    - fuel filter renewed
    - air filter checked
    No luck so far.
    I tend to think towards the fuel pressure regulator and probably that's what I will try next (crazy dear they are at Mitsubishi dealer, found one on ebay, for Diamante).
    I don't have a fuel pressure meter to test the fuel pressure, did a rough test by attaching a clear hose into a bucket to the regulator return end. The flow was ok, it was changing when I was pulling throttle lever (the flow slowed down when I opened the throttle) so it looked like it works fine.
    Another thing I noticed - I used to hear the fuel pump noise when turning the ignition key - ignition is on - the pumping sound - start. Now I can't hear it any more. Something wrong with the pump?
    So I am stuck at the moment and would appreciate any advice or an idea where to look at next.
    jimbeam_james's Avatar
    Feb 2006
    id sont really have much clue, but i had almost the same issue in my lowlux turbo, and it turned out the afm was round the wrong way so maybe its sumthin to do wif ya air flow meter?
    just a stab in the dark?
    Banned Disciple's Avatar
    Aug 2005
    Plugs/leads. Replace those.
    Aug 2010
    thanks James for the quick reply.
    I tried to disconnect the air flow sensor - the engine runs crap then even while idle. I will check the voltages there once this rain is over.
    Forgot to mention - I checked ECU fault codes - no errors were "blinked out"
    ***<<< PHIL >>>*** Elwyn's Avatar
    May 2008
    I'll go with Disciple, with the proviso that you check each plug for condition as you go - and keeping in-mind that you suspect it hasd jumped a tooth on the Timing Belt.
    Condition of plugs may give a clue about whether you have good/even compression on all cylinders and spark timing for all cylinders.
    If it is intermittently strong/normal, then maybe plugs/leads or dizzy cap (tracking) could be cause... rather than something more permanently nasty like a damaged valve if belt had jumped.
    Phil
    TJ Sports '02 ( 5 man ) - bit of a roughy.
    KJ Verada '00 ( 4 tippy ) - smoooooth!
    Apr 2010
    Easy way to check if there is any high voltage tracking on leads/plugs/dist cap is to look at the engine running in total darkness.
    Aug 2010
    checked for voltage tracking tonight - no sparks seen, will replace the leads/plugs anyway, will replace the fuel pressure regulator too. will update with the results.
    Jun 2010
    Ive been having the same troubles, and have tracked the problem down to leaking exhaust manifold gasket, and manifold to exhaust pipe gasket, have checked my catalytic converter and the guts have blown out, so Im also suspecting possible restriction in the exhaust pipe and rear muffler as well. Managed to get it running perfectly after tightening the rear exhaust manifold nut that had come loose, but the gasket was already blown at that spot and it soon played up again. Anyway, just a thought.
    May 2007
    Hi all well i have been chasing this exact problem for the last 18 months . Started with just stalling after cold starts when the car would pul up after the fisrst corner or T junction. Spluttering , coughing and finalally stalling after pumping the excellorater.
    This progressed further to doing it all the time even when it was warm , the pedal seemed to get hard or feel like it was pushing back and then all of a sudden take off like a cut snake.
    We changed plugs, leads , battery fuel filter all the easy things to no avail. We then changed the airflow sensor and filter , throttle body was next , stepper motor and even the TPS sender.All the same results still playing up.
    We then swapped out the ECU , coolant sensor for ECU had Mitsibushi look at it and check all settings and still no luck , not even any sugestions from the dealer .
    The fix finally came in desparation when i had a O2 sensor given to me even though it was a toyota one i decided to change it out .Had to rewire the sensor to the mitsi plug as it had different colors to the toyota ones . When i took the old sensor out i notice it was bunged up with massive amounts of carbon , black soot etc.Started the engine and gave it a couple of revs to blow the excess soot out and there was heaps of it .All back together and thats the problem fixed , hasnt missed a beat since goes like a race car all the time its great to get it back to normal again.
    O2 sensors should be changed every 100,000 Klms and are never done im told.
    Aug 2010
    castnet and Hughy69, thanks a lot guys for your replies. I have replaced the fuel pressure regulator this morning (just arrived from US), replaced plugs and leads a week ago - no luck, all the same, bugger. Was thinking towards replacing fuel pump, throttle body and ECU but decided to check the thread. Will check the exhaust system, I replaced the rear muffler a year ago, it was rusted out so there could be something wrong up the pipe too. Will check O2 sensor as well. Will be back with the result.
